Hope someone can help.
So i fitted new BOV's yesterday and completed the job today - my first attempt at any car work so took a little longer than expected.
With all trim out of the way i dsconnected the standard valves and removed them. Replaced them with new ARC BOV's all fittings and gaskets were used correctly and all piping reconnected. The recirc pip was bunged up using the supplied bung.
Started the car no idle issues, revved quite low and no dump, revved harder still no dump, revved to the limit and still no dump - only noise coming from my Apexi Filters.
So decided to put everything back together and take it for a test run. They still arent dumping but now they are making a whining noise on boost. Again all idle and other guages read fine.
The car is standard apart from the Apexi filters and and Exhaust.
Does anyone know what the issue might be or what i have done wrong. I have pics of the install if that would help?
Vinay
Vinay
