1 - 7 of 7 Posts
Quick question guys - at what horsepower do u require to change the standard RBOV, or don't u ??
If not have any of you lot changed them and noticed any difference ?
cheers
Daz
probably "need" to change them over 700PS
however most people don't change them because they "need" to be changed;) :D
You'll definitely notice a difference, mainly that your engine will stall quite easily:p :D
it sounds nice.. one thingy I have noticed about the STD BOV it does not rerout the vented air.. a little hard for me to explain you have to see it yourself ...
But if you want aftermaket Bov's rerout them back and you shouldnt have a problem stalling your car.
Actualy a aftermarket BOV should be better for saving your turbos than the STD BOV at any given pressure of boost or HP application.
Ohh yes Turbo Magazine this months issue has a lot of information about BOV's, FINALLY SOMEONE actualy put them all on the table... it doesnt compare them just gives you the fact of each BOV how its built and what their spring rates are with priceing ,, helpful
1 - 7 of 7 Posts
