can anyone tell me the spec of the radial bolts that hold the brake calipers to the upright/bracket . I picked up a st ceramic kit including the spacers but no bolts . im looking to order some rears 10mm longer than stock and fronts 5mm longer for a dba car but as I don't yet have the car for another week or so I cant measure them.
cheers in advance.
Have you seen how far the bolt goes into the hub? I dont think there will be a problem running cba bolts.
I don't have the car to hand so I cant check on the thread depth. I was just working on the assumption that the bolt wanted to be same length as factory spec plus the thickness of the spacer ie 5mm front and 10mm rear. I just want to do the swap in one go rather than pulling it in bits then ordering bolts in.
