1 - 9 of 9 Posts
Hi all.... This is the second time it's happened it feels like the pads come loose after a spirited drive, pull over stamp on the brakes and all sorted.... Any ideas how to stop it?? I've got oem discs and about 8mm pad left
Brake Judder is normally a sign of warped discs, maybe the warping is exaggerated when the discs are hot..
Take to a specialist to take a look, you don't mess around with breaks....
Yea i have experienced this too at my last trackday at Silverstone..
Definatly not warped discs because its fine now.. Either way my OEM discs have started cracking, so.. over to Litcho soon :)
People fail the understand that its actually very difficult to warp a disc...
I've experienced this on my old OEM discs after a few high speed braking sessions. I haven't had the chance to test out my new discs in anger
If the disc was warped they would be like it all the time not when they get hot,
I've had this twice not on spirited drives,
Litchfield Tec man today said it's more than likely brake pads leaving deposite on disc when hot, then wearing off the next couple of uses,
Going to clean all the holes in the discs to help heat dissipation,
I'm still on original discs as well 14000 miles and no signs of cracking. YET
Goldie
Discussion Starter · #9 ·
Goldie
Sounds like my issue too..... I'm at 32k so must have had a new set of disc.... Not that I can find any record in the history so must be on my second
1 - 9 of 9 Posts
