1 - 7 of 7 Posts
Hi,
At Sumo we have the new Do-Luck PowerLine brake hoses available for the R35 GTR, as installed on both of our own GTR's.
Do-Luck never mess around with products that have no purpose and the Power Line range is no different - increasing the braking feel, and energy put to the brake pads, they are a good DIY upgrade to your brake system, easy, affordable and with a noticable difference over the standard rubber lines which amazingly still appear on the R35! They are part of our recommendation to upgrade the lines and pads on your GTR for increased braking in keeping with a more ''higher performance'' driving style shall we say :D
Power Lines are direct replacement brake lines for your R35 GTR and come as a complete kit with instructions and necessary fittings. If you have the basic skills they are DIY however we would recommend they are installed by a professional - if need be we can install them for you at our facility at a small extra cost. We also supply Motul RBF600 brake fluid at extra cost and can supply both items via mail order, no probs.
The best part is that they come with a lifetime no quibble gaurantee and are available from stock at just £55+vat for a set.
You can only buy the lines directly from us and online using the link below, just click the picture to be taken to our webshop
These PowerLines are exclusive to Sumo Power.
R35 GTR :-
Any questions, just ask :)
Mark
Sumo Power Ltd
Thanks for the info Robbie.
Interesting that Stillen make a big deal out of retaining all the factory hard pipes in their blurb for their Goodridge made set: STILLEN Premier GT-R Catalog
Costs nearly 4 times as much before shipping and tax!
And Gary Finney from Middlehurst reckons weatherproofing is important even for stainless steel braided hoses and the Do Luck set has that.
How long did it take you to fit and how much fluid would you need assuming you're not replacing all of it? (I already have Motul RB600 in the system.)
Lines
Do these replace the factory hard lines too, or just the rubber ones?
And they're stainless braided Teflon lines with a plastic sheath?
Hi David,
Yes they are, but they are also fully stainless including the ends and fittings so they will not corrode over time. They replace the rubber hoses only on the car ( no effect / point in replacing the steel ones ) - nice and easy to install.
We can also supply you with RBF600 at the same time if you need some sending out with the lines.
You should also be aware of our latest offer if considering a complete Stage 1 brake upgrade without going too serious which is here : http://www.gtr.co.uk/forum/128401-r35-gtr-brake-upgrade-deal-sumo.html#post1212963
These lines have been available from us for the best part of a year and we have sold around 500 sets this year alone. We have a complete range for many applications, all come with a lifetime guarantee too.
Hope the info helps, if I can help further, pleased to hear from you ( 01797 222281 / caroline AT sumopower.com / Sumo Power | The UK's Number 1 for japanese performance parts )
Caroline.
Sumo Power Ltd
1 - 7 of 7 Posts
