I need opinions
I itried bleeding my brakes this morning, as i lost the brake pedal, but it seemed as the backs bled ok, but when doing the fronts, loads of air came through. It just never bled out. Then, as i was pumping the pedal, i noticed good sized air bubbles coming up through the resovoir with every pump of the pedal.
Is this the cylinder? And do i need the servo part too, or just the actual silver cylinder bit?
Help, as i'm itching to drive my car again!
