1 - 13 of 13 Posts
Cams suit R32 and R33 CAS. Will work with R34, but will have to Mod CAS. Cams are brand new, and were only installed in head but never run. NO WEAR at all, brand new.
Picture shows springs, but they were sold and are not for sale.
HKS Step II 280 duration, 10.2 lift, intake and exhaust cams. Can include Nearly new HKS cam gears for added cost.
350 ono + shipping, For CAMS alone
130 ono + shipping for HKS cam gears
450 shipped For both
Yes. You will need to have the head clearanced so the lobes do not touch, and then have the head shimmed. I have Tomei +1 mm buckets new in box to go with, but they are another 200 UK pounds.
Discussion Starter #4
Also for sale.
TOMEI +1mm lifter Bucket set, NIB only installed, but never run. With these buckets, the cams should not need much shimming if any from your stock setup as they take up the space of the high lift cams smaller base circle. CLEARANCES STILL NEED CHECKED!
200 + shipping
500 for both Lifter buckets and cams + shipping
600 for ALL, Lifter buckets, Cams, and Pulleys.
Discussion Starter #6
Cam Gears provisionaly sold.
2 day STEAL on the Tomei lifter Buckets and HKS Step II cams.
450 OVNO + shipping for BRAND NEW HKS Step II cams and Tomei Lifter Buckets.
Need to clear out my spare parts! Will soon have an Forged RB26 N1 bottom end for sale. Tomei 2.8 on the engine stand.
Spec
24U block
HKS pistons
Eagle Rods
N1 Crank
Full Sump and front diff with Tomei baffle kit
Greddy oil pump
ACL race bearings
Perfect compression 170, 171, 169, 168, 170, 171
Only Short block with sump no ancillaries or cylinder head. Motor still in car, can send pics and videos of it running with pressures ect. Motor made 700whp on GT4088R and is now running a GT42R. Fully balanced and clearanced for higher boost, but not a "breather". All work done in Japan. Motor has done 5K kilometers
This is just a heads up if someone is looking in the near future, but can remove if needed sooner. 2200 + shipping
Discussion Starter #10
Pulleys are sold.
Cams are still available, these are 229.55 EACH new from Nengun.
These cams are NEW just installed for mock up and removed. 460 worth of Cams for 300.
1 - 13 of 13 Posts
