1 - 20 of 60 Posts
Hi Guys
by popular demand Im breaking some more GTR's. I have just picked up a white 32 gtr bristling with NISMO, MINES, ARC, CUSCO,GREDDY and much much more.
I'll post a listing up asap. First come first served as per usual rules, no dibs or reserves without payment.
N1 Headlamps, GTR grill, Oil Cooler, Twin plate clutch, aftermarket strut braces, NISMO speedo, the extremly rare centre consul trim and more.
Im afraid to mention that as we a re now VAT registed there is a nominal increase in our prices, but were still the best and always offer great service.
List up soon.
DaveW
Prices and parts to follow. Nice stuff.
What intercooler does it have Dave?
bob
Discussion Starter · #14 ·
Complete and detailed list going up tommorrow morning.:thumbsup:
Discussion Starter · #19 · (Edited)
All prices plus shipping
All GTR parts
NISMO down pipes £145
std front bumper 149
gtr rear spoiler 129
trust oil cooler and filter relocation kit 299
16" std gtr Alloys with excellent tyres 349
Apexi PFC 369
centre consol trim 58
twin plate clutch 499
greddy 52mm boost pressure gauge 59
greddy 52mm oil pressure gauge 59
greddy 52mm water temp gauge 59
adjustableH/D rear brace 49
P Lap II Lap timer 75
race tow eye 60
HKS air filters and elbows 139
nissan oem strut brace 45
rear lsd 299
RSR Race exhaust 249
greddy uprated rad hose kit 69
white background R32 GTR boot badge 34
NISMO 320kph clocks 159
r32 Aluminium wings (each) 119.00
MINES (NISMO) afms 399.00
front diff with sump 149.00
complete std radiator with coweling 49.00
555cc NISMO inj 369.00
passenger side air vent 54.00
centre airvent 54.00
GTR front seats 229.00
cylinder head 499.00
GTR Aluminium Bonnet 199.00
door rubber seals - each 18.00
GTR Crank 449.00
rear seats £79
rear hubs inc wheel bearing assembly £55
aftermarket s/wheel and quick release kit £150
coil pack loom £49
front hubs inc wheel bearing assembly £45
OEM Plastic gtr side skirts £80
clutch slave cylinder £45
ignition pack £88
Hicas rear rack £59
RB26 coil packs each £19
R33GTR Turbos, excellent condition £349
32 GTR Block £499
CAS £79
front 1/2 shafts pair £139
full boot internal £80
rear shafts pair £129
NISMO rubber/abs side skirts £189
A/C pump £40
overhauled GTR g-box, only covered 12k £350
front screen £449
rear screen £50
bonnet catch and support bar £49
Starter/battery/alt harness £45
std cams £59
excellent doors without glass or fittings £29
door mirrors each £36
OS N1 headlamps £129
NS N1 headlamp £129
R32 GTR Grill £59
boot/fuel release and cable £20
knock sensor harness £25
bootlid £30
rear seat side panels £40
door cards £70
carpet in v/good condition £40
skyline matts with original floor fixing kit £49
ecu harness harness £150
rear lights each £30
cusco brake stopper £89
Thottle [position sensor £45
skyline sill trims £20
alternator £79
s/motor £39
ind stalk £25
full lock setwith key £80
R33 GTR viscous & fan, much better for cooling £79
seat belts £50
steering rack £120
Monster Oil catch tank £69
gtr triple gauges £25
glove box £15
arm rest/starage bin and lower centre consul £30
PAS pump £69
A/C rad & Condens £45
rear bumper £40
Central Racing Race spec ECU £199
Front ashtray £22
G-Sensors £349
h/lining £30
o's indicator, clip damaged but in perfect appearance and order £55
n/s indicator £55
F brake setup with slotted discs £159
h/brk lever + cables £25
g'lever £20
A/C control unit + Sensor £40
Boot GTR badge £15
cabin courtesy light £20
ash tray £19
Uprated upper breather kit £49
front wiper motor £35
bonnet release + cable £25
front prop £49
rear prop £149
brake mstr cylinder £35
heater fan £30
clutch slave cyl £35
door window/lock switch & relay £35
a-pillar trims each £20
tomei fuel pump £100
red GT wing badges £15
throttle bodies £80
hub carriers each £40
knock sensors each £40
sun visors £20
clutch master cyl £48
fuel tank £30
o/s door handle £20
n/s door handle £20
front bumper support bar £140
rear bumper support bar £100
centre consol clocks surround £30
wheel arch liners each £45
Coilover kit £399
clock binnacle with headlamp switch gear £45
fuel sender unit £25
rear wiper motor £30
complete door/boot seals £80
boot lock areaplastic trims £20
undertray brake air vents £25
washer motor £20
ruuber turbo 1/2 pipe £40
rear brake setup £80
speaker grills £21
inlet plenum with associated water pipes £80
ACC valve £38
door hinges each £14
lower dash trim and fuse box cover £20
ARC BOV and hardpipe £99
r/rack rod end £29
n/s rear hub £40
greddy tt £30
ac pipes £50
heater matrix £45
rear quarter glasses each £55
OEM tool kit, still in sealed bag!!!! £29
1 - 20 of 60 Posts
