examples
electric ariel £26
wings £150
doors £50
door glass £79
1/4 glass £55
ignition barrel/key £88
front rack £140
rear rack £80
carpet £49
rear screen £180
inner rear cards £48
inner rear upper trims £48
bootlid £80
rear spoiler £280
rear subframe £199
front subframe £199
sill trims £19
passenger door trim £49
dash pad £69
clutch master cylinder £49
clutch slave cylinder £39
brake master servo £79
rear 1/2 shafts £79
rear 1/2 shafts v-spec £99
v-spec rear lsd £349
rear hubs/bearing £49
front hubs/bearing £49
rear hub carriers £49
PAS fluid bottle £39
Carboncan £39
ABS pump £149
rear wishbones £49
rear upper arms £19
ARB front £49
ARB rear £49
Battery harness £59
v-spec NISMO clocks £349
std 33 speedo clocks £149
Accontrol panel relocation kit/harness £80
door handles £30
boot lock £30
All above prices are as single items not pairs, all plus shipping. Over 2000 more 33 parts in stock
electric ariel £26
wings £150
doors £50
door glass £79
1/4 glass £55
front rack £140
rear rack £80
carpet £49
rear screen £180
bootlid £80
rear spoiler £280
rear subframe £199
front subframe £199
sill trims £19
dash pad £69
rear 1/2 shafts £79
Carboncan £39
ABS pump £149
rear wishbones £49
rear upper arms £19
ARB front £49
ARB rear £49
Battery harness £59
door handles £30
boot lock £30
