It's a bit complicated this so I will try to keep it simple.
I had built a new engine for my R34 (as well as buying lots of other stuff) but have since bought a nice R33 GTR with a 2.8 HKS motor and TO4Z. I am going to split the car and use that engine instead.
So I am selling the following engine that I no longer need and selling all the bits of the R33 including the shell. Below is a spec of the car.
Standard Gearbox rebuilt with close ratio OS GIKEN forged gear
set
1st through to 5th , OS GIKEN Centre plate,
HOLINGER Uprated input shaft Input Shaft
TS Grid Dancer which allows permanent RWD,FWD,or
Any combination to 50/50 split
OS GIKEN R4C Quadruple plate Clutch,with alteration kit and
HOLINGER hub
NISMO LSD GT PRO 1.5 Way rear Diff
Crux 18 by 11.5 wheels with dunlop SSR tyres (yes they do fit)
Full set of R34 Brakes including pads and disc front and rear.
Full set of R33 brakes with braided hoses and ferrodo pads.
Apexi Power FC and comander
Nismo AFM's
Xenon headlights
Complete interior with custom leather re-trim. (Including all door cards and parcel shelf trimmed!)
SX in boot fuel pump.
HKS Drag spec exhaust (Titanium)
HKS EVC 5
Grid dancer torque split
The new engine is a s follows:
HKS Pistons (2500 miles old)
Tomei Rods (2500 miles old)
Std Crank (New)
Trust Deep Sump (New)
Trust oil pump (New)
Nismo water pump (New)
Nismo Thermostat (New)
Tomei Step1 cams (New)
Tomei Cam wheels(New)
HKS Timing belt(New)
Tomei Gasket set inc 1.2mm head gasket (New)
Apart from all that it has had new bearings and seals and bronze valve guides fitted. Also new cam covers all powder coated in candy blue.
As well as all this there is a complete car with things like dash, clocks, momo wheel, Greddy guages.
Please PM me with what you want and I will let you know price. The car is being collected tomorrow so I will have more pics then. The interior is below.
Or you can call me on 07770 765995
set
HOLINGER hub
Nismo AFM's
Xenon headlights
HKS EVC 5
Std Crank (New)
