1 - 13 of 13 Posts
Brand new pair of Brembo 8 pot monoblock calipers. These calipers use 4 [four] pads per caliper and have dustseals on the pistons.
Ultimate front brake calipers
Suitable for 355mm to 380mm rotors
Part numbers
20424506
20853620
£900 inc fast road pads or £750 for just calipers
NO OFFERS INC UK next day courier delivery
would these fit to a standard R32 GTR which currently has 4 pot brembo's dyu think? as i need more stopping power ;)
cheers!
Discussion Starter #4
cheers!
You need larger discs than std with these calipers [355x32 minimum].
Discussion Starter #6
NITO said:
Cam,
Do you need mounting brackets for these to fit or do they bolt direct in place of the stock calipers?
Regards
Nito
Hi Nito
They are radial mount and require brackets. I can either supply dimensions or can get some made to suit discs.
Cam
mounting brackets got 8 pots
Cossycam are you still on this board? tried to send you a PM but your inbox was full, do you still have the drawings for the mounting brackets for these calipers? i'm thinking of getting these calipers and would need to machine my own brackets, your help would be much appreciated.
Aktar
Dont think so the calipers look way to big to fit under 17" go on google images and do a search for lambo gollardo and you can see how big these calipesr look when they're actually fitted.
<sigh> oh well. impractical for R32 I think anyways, as 17" is the ideal wheel size, and 343mm rotors is what I'll have to get. But 8 pots and 18" would look mad-tyte yo:clap:
or can 8-pots like these be fitted to 343mm rotors?
Part numbers
20424506
20853620
At the risk of sounding stupid...Is this one part number for nearside and one for offside??
Cheers,
J
Could possibly fit, ive got SL55 brembo calipers converted 348 8pot frnt and 330 4pot rear on r34gtr on 19's. my first attempt on conversion is the reason for the small frnt disc. Will eventually fit 355 maybe 360
1 - 13 of 13 Posts
