1 - 8 of 8 Posts
Hi All,
On my 33 GTS-t, seems I have mullered the rear diff. Anyone know if I can get the internals rebuilt ?
I am looking to change the ratios to 4.4 ish, hence not just getting a replacement.
4.3's are the only crown wheel and pinion you'll be able to get, you've probably just mullered the lsd so your crown wheel and pinion should be ok.
Neil
I have a 4.363 in there at the mo from an Auto.
Are there not companies out there that make cogs ?
Not fully under standing how LSD's work, how would I have broken it ?
The crown wheel and pinion are 2 seperate gears to the lsd and this is what gives you the ratio's also they're not part of the lsd.
You can buy an lsd with different ramp angles which will give you more or less traction on and off the excellorator but as far as i know you can't buy after market crown wheel and pinions but i don't know for sure.
Moffy Boy,
best diff is the Pro Nismo diff allows you to adjust the breaking preload of the L.S.D without removing the diff, alos has 2 sets of preload ramps built in the diff i/e acceleration/braking ramps but to change these you need to remove the diff complete and strip it.
Give me a ring to discuss if you want to.
Mark
1 - 8 of 8 Posts
