61 - 80 of 159 Posts
Group A parts
It's a collection of parts originally used on several cars in period. Each car had a comprehensive package of spares, and stuff got swapped around all the time ( what with crack testing after races and tests, rebuilding, rebushing etc etc ).
The Quantums were for use on a later privateer car which used some of the Gr.A parts. You can see some original Kayabas underneath them in the photo.
Alan, in the last week I have done a lot of research on the Group A suspension parts, the goose necks above don't look like to original ones that were homologated. Could they have been fabricated by someone other than Nismo?
Amazing have been after pics of front suspension for years!!!!
and it was as easy as that, Just asking at the right time.LOL
would that be the same setup as the Gibson cars?
Gibson cars ran 10 inch wheels where built up in Australia with parts where as the Group A cars built by Nismo had 11 inch wheels. The Nismo cars were also developed over the years, for example there were various subframe versions, different driveshafts (Some CFRP) etc.
Group A
From what I have found out the Nismo Group A's were the only factory built cars, these where the real Group A cars, the Gibson Motorsport GTR's were made up locally out of some of their Group A parts. For example the rear suspension arms were different . I have both types and are using the Nismo stuff in my suspension. Also the Gibson ones didn't use the magnesium transfer case or the rear AP brakes (They used Harrop's) or carbon drive shafts etc
Here is a pic of my syspension arms, Group A Nismo on top and Group A Gibson on the bottom of the pic. Also the Nismo item uses stepped high misalignment shperials made by NMB Minebea (Make parts for Airbus and the Boeing 787) and the Gibson one doesn't.
Rear tie rod bracket also different on Gibson upright
Here is apic of a part I have
You lucky man!!!
Cheers for sharing!
bob
Sorry, didn't see this question until just now.
Which 'goosenecks' are you asking about? All the stuff I photographed came direct from NISMO, and was used on 'factory' Gr.A cars in period. It has impeccable provenance, and indeed it all *belonged* to one of the factory team drivers.....
One thing that I think it's important to remember is that there was a long period between the initial homologation and the end of the true 'factory' use of the cars and parts in period. Where anything was clearly different to the originally homologated parts they would need to be added to the original FIA homologation as amendments ( with photos, a technical spec and relevant dates noted on the FIA papers ) to keep it all above board, but if the differences were marginal - or if they thought they could get it past scrutineering without any trouble and not be protested afterwards - then later parts could well have slight differences to the earliest versions. There's a good few years of use and development / update 'in period' that we are covering here, after all.
Wouln't surprise me if details on the later Gibson stuff was slightly different to the earliest ( NISMO ) produced - and properly homologated - items. Gibson would probably be able to get some of this stuff made up locally for less than what NISMO would have charged them for it I bet. They'd incorporate their own tweeks and nobody would be any the wiser if it wasn't all that noticeable once on the car.
What's the provenance of the parts you are identifying as NISMO Gr.A in your pics? Are they dated or marked in any way?
The Gibson subframes are completely differet to the Nismo ones (the pickup points have been moved a lot), Nismo had one version in 1990 and a complete different one for the 1991 season, I have pics of these, which I may post later
They aren't dated or part numbered, but a guy I know who worked for Nismo and has supplied me all the suspension setup specs has looked at these gooseneck pics and showed me ones that he has of the originals and the detail and quality are quite different. I will be using the Nismo arms in my car and keeping the Gibson ones as a spare. The Gibson ones can't be used without major mods to the subframe
The front and rear hubs are part numbered
You're implying that the parts in my photos are not "originals" then?
No not at all, what I am sayig is that they don't look like the originals, the original ones have an offset top mount which is necessary to clear the upper arm when the suspension is at full travel up.and the rear portion has a bend that is slightly higher to clear the wheel when on full lock which by the way is 19.5 degrees in and 20 degrees out (This is what Nismo has recorded in their tech specifications) To use this arm that you show would require a major mod to the upper link. I only have a printed copy of my Nimso pics but I will scan and upload. I also have pics of the 1990 and 1991 rear subframe which are both quite different from each other and interesting completely dfferent to the Gibson version (Which I imagine Gibson made themselves)
Gibson also made different spindles for the hubs because the wheels kept coming loose, they have a much larger diameter than the Nismo's I have a set of them with my hubs (Nuthas a 72mm thread - Huge)
gearbox
Here is a Gibson Holinger gearbox I have, this is rare, one of only 3 made in this configuation (Magnesium bell housing), most were alloy and some were full magnesium. This one also has a very nice hydraulic release bearing system
Interesting thing is Gibson cars never had the magnesium transfer case or the CFRP driveshaft that Nismo had used
What's the comment about "quality" meant to mean then?
And what "originals" are you talking about? To my mind, the "originals" are the first version in the JAF/FIA homologation papers.
You need to clarify.
They look as though they have been fabricated by hand, I will soon post a pic to explain. I am not aying they are not fro out of Nismo, what I am saying is they don't loo like the ones I have pics of. If you look back earlier in the thread there is a breakdown of the Calsonic car, the ones I have a pic off look like this. Maybe the ones you have a pic of are development versions.
Baz,
I think you might not realise quite how special the Gr.A R32 suspension and drivetrain parts were...? They were really nothing like the stock parts.
As I mentioned in my original answer to this post ( crikey - it was years ago...! ) the homologated race parts were a package that you can't really replicate with off-the-shelf-parts today. Especially on a road car.
As a few pictures might get this across better than I can with a thousand words, take a look at these:
Cheers,
Alan T.
Have a good look at these ones, then compare to the ones below, they are different
Where do you guys find all these parts and info. Would love to be able to get my hands on some. Incredible knowledge guys :)
First image is a page from the Ishida / Gran Prix Publishing R32 race development book, showing the 'Ext-Compl. Knuckle Arm' / "Gooseneck". The other three extra photos of the same parts I showed earlier. Admittedly they are a bit dirty and used, but they are genuine works Gr.A NISMO pieces with correct provenance.
As I've been saying, parts specs were developed and changed all the way through their in-period race life. Many of the things you are pointing out were detailed in the FIA papers as full amendments to the homologation. For example, there are at least four different versions of knuckles and the crossmembers changed three times before the end of '91. Have you got a full set of the A-5405 / JA-137 papers to refer to?
There is discussion / explanation of the works setup data in the Ishida book, so it's not a secret as such. Just it does not mean all that much on it's own, and can not necessarily be applied to any car that does not use all the relevant parts.
I have this book also, and it has some interesting info in it.
Can you see what I mean about the upper mount point not being offset.
I do think yours are originals, but I also think they may have been a development piece given the difference inappearance.
Blow this pic up and have a lok at the top mount, this is the difference I am talking about. Even the bends on the gooseneck's look substantially different
Why would you be surprised that parts changed spec / detail / appearance during a three year period of racing and development?
The parts in the photo you are referencing were fitted to the #12 Calsonic / Impul Racing car during 1991. There was a full year of racing before that, and a full year afterwards too. To use the photo as if it's somehow proof of only one type of 'gooseneck' is clearly a mistake.
You're calling into doubt the authenticity of the parts I photographed and showed here. I think you would be well advised to look into the subject a bit more deeply before you jump to conclusions and start pointing fingers.
Hi mate what size are the tubes & rod ends on these ?
Nigel :thumbsup:
