Looking to tap the cam cover breathers and to avoid getting any cuttings in the cover looking at removing the baffles so I can clean them out properly. Seems to be easy enough as just bolted down but there is some sort of sealer round the edges. Questions are
- What is the sealer (assume high temp) and where can I get it?
Is there anything else that makes this more tricky that it seems?
We use Nissan red rtv too just a v thin layer.
Be carful not to bend them and go easy on the small screws, old ones have been known to snap. Also take a pic before you start just so you know which way they came off.
There's little gauzes inside too, give them a clean with brake cleaner.
Make sure you get a little bit of Nissan red on each screw thread as it goes back in to prevent them falling out too, (like locktighting).
Bob
