Just trying to decide which would produce more power. A set of poncams and just staying at 1.1 bar or fitting better turbo's and boosting to say 1.5 on the stock cams?
Secondly, cost will be a minor factor. Turbo's I would be able to fit along with the fuel pump, inj, and AFM's but I won't be able to install the cams. What are you guys paying for cam installs? I'm not counting mapping/dyno time as it would be the same for both more than likely.
