I was talking to someone the other day about setting cams and they were talking in mm at TDC?? I have not come accross this before. Does this refer to the amount the valve should be open by when the crank is at TDC? If you have retarded your cam timing then would your valve not be closed anyway at TDC? If so how can you set it by mm?
Thank you
Lee
