i have fitted my rb26 with hks 272 10.2 mm cams and valve gear with hks slide sprockets just wondering will the the car start and run ok if t set the sprockets in the central position i just need to run the engine in before i get it mapped and set up properly.
It should indeed start with them zero'd. Before you get it "set up properly" make sure the map in it that you will use to run in isn't going to do any damage.
Discussion Starter #3 (Edited)
cheers cord ,just the guy i wanted to hear that from ,a so called engine "expert" told me it wouldnt run at zero .....i disagreed ,the map ill be using for the run in period is pretty mild it was a map for a stock engine with 600cc injectors and steel tubs @1.3 bar surely this will be ok to run it in gently
Skyline Section Manager
I have Jun 272 cams. If you set them up as the instructions say, everything will be good.
