1 - 20 of 28 Posts
On my last 4 wheel alignment it was noted that they couldn't achieve the correct camber settings for my current ride height due to the camber arms being seized. The suspension is completely standard except for the coilovers that were fitted when it arrived in the UK. All old af.
I'm going a touch lower on the ride height soon and I'm looking to freshen up the suspension and get the camber right - however it seems far more complicated than my little old integra DC5 I used to have. On that car it was 2 rear arms, and 2 front camber bolts then a geo setup, job done. The bit I'm getting confused about is what I actually need to buy. I know next to nothing about suspension, and even less about the R33 suspension..
Originally I was looking at a driftworks 'kit' simply because... it's all in one package. However I think maybe I could spend my money a little better after reading not-so-great things about DW items. Looking at RHDJapan there's lots of different companies offering far more than just rear camber arms.
For example Cusco have Negative upper A arms, Adjustable upper rear arms, adjustable rear upper arm links. Do I need all of those items just to be able to dial in the correct camber? Do I need things like tension rods?
The car is only driven on the street and won't see any track use.
Could someone please simplify what I should actually be buying, what's not worth buying (because I see some stuff is aimed at track cars) what companies are good etc.. I'm totally in the dark. Also would it be worth freshening up some of the bushings? Would changing something like the sub-frame or steering rack bushings make any noticeable difference?
Ideally I'd like to keep the price for the whole lot under £1k with a HICAS lockout kit included in the price. Again I'm only after items that'd be beneficial to a street car :confused:
Ive been in a similar boat....Pun intended.
The camber on the rear shouldnt be too bad depending how low the car is but the front will need camber took off. Mine currently has far too much on the front so I have bought cusco front upper camber arms and whiteline our top arm bushes. I also have new whiteline front and rear arbs with new bushes and links to go on.
You can also get hardrace here in the UK which will do the job and are around £300-350 for the front upper arms. Rear camber arms being circa £170.
For UK roads id keep camber settings to no more than 1 degree on the front otherwise it will dart all over the place with the uneven/adverse camber on the roads. If you cant take enough off the back just get a set of rear camber arms and do both. Dont go too low on the back because when the car squats the camber can increase dramatically, decreasing traction.
When you start taking the sub frame off the cost will shoot up due to time...then you may as well rebuild the whole sub frame. If they dont look bad Id leave them until you can have the frame redone.
As for replacing bushes...Do as many as you can because it will make a world of difference.
I had a jdm dc2 and the multi link on them means more bushes etc. The dc5s downfall imo was the suspension design, let down by the lack of rear multi link setup and the front steering geometry meant that lowering the cars beyond 1 inch would cause a whole host of problems. The ep3 having the same problem basically being the same car.
Contact cougar power motorsport uk on facebook, speak to them about a whiteline bush kit. Mention steve @carcultured apparel, they will get a good price.
Discussion Starter #4
Thanks for the reply's lads. Red Duke, I've got the same problem currently with my fronts wearing right on the inner edge.
So purely for example, if I ordered
this
and
this
I'd be all sorted? Or would I need tension rods? Lower control arms? or are those just fancy extra's to tweak/enhance the handling even more?
this
and
this
Go hardrace and save paying import duty etc and waiting for them to arrive. Get front and rear camber arms and replace all the bushes. As for other arms, I wouldnt bother atm but replace the tension rod bushes while you are at it.
A lot have spherical bearings so avoid them for a road car. Also Id go for a 1 piece upper front camber arm.
this
and
this
I wouldn't like to say mate tbh, I've not sorted mine yet, hoping to drop it off tomorrow when I collect my GT86, see what the garage say once the ride height has been taken up! My rears seem to be fine, I've had all new bushes and bearings when it was all refurbished so I can't say if that has changed my rear camber or I'm just too low, hence the inner front wearing. I also rub on full lock too, so something needs to change!
The RCA's seem to put the front arms back to OEM position (even when lowered) so should sort the camber? I hope!
From my experience its actually the toe setting rather then camber that affects the inner tyre wear.
Indeed, I had 5 deg of toe set on the front.....and thats apparently with a professional alignment... my nut sack (£75 down the spout) Was starting to scrub out my brand new Eagle F1 Asymmetrics in 400 miles :eek:
Too many cowboys out there :double-finger:
Discussion Starter #10
Do I need anything to adjust the toe or will oem suffice?
In terms of hardrace stuff, their front camber kit seems different to other brands, and is double the price?
Hardrace front camber kit
where as japspeed's front camber kit for example looks different - here. Assuming ones upper camber arms ones lower?
Japspeed also do a kit (here) like driftworks - assuming it all comes from the same factory though?
Generally, you get what you pay for. I have oem toe arms and they have enough adjustment for my setup.
Owner of the MSNSPS
I have spherical bearings on my road car...
Decent bearings with a rubber boot last well enough.
Discussion Starter #13
Mini-revival.
Are these 2 parts the same? Cusco camber hardrace camber
Not sure why the cusco's are half the price of the hard-race version?. One thing I'm concerned about is on the RHDJapan site it states on the cusco arms:
COMPATIBILITY NOTES:
- Skyline: Only 2WD Vehicles (GT-R Excluded)
This camber stuff is starting to fry my head a bit. Want something that's decent which doesn't cost the earth to buy.
FWIW I wouldn't buy the DW stuff, I had their arms on my R33 and had to get the alignment done every 3 months or so because it kept working loose.
Discussion Starter #16
Their design seems to be exactly the same as most of the stuff from Japan. Only reason I haven't ordered them is because of what people on here have said. Saying that it's nice of them to offer the whole lot in one kit - shame no other company is doing that. Well besides Japspeed that is. I hear they come from the same manufacturer, although the japspeed stuff has slightly different designs for some of the arms. They don't seem to be making it anymore though.
Are traction/tension rods essential for dialing in camber? or is it more of an added bonus? I'm not planning on tracking the car.
At the moment I'm going to order hardrace or cusco for the front (assuming they're compatible with the GTR, if someone could confirm that'd be great) and hardrace rear arms. Also get a HICAS lockout kit. Is there anything else I'll need?
Read the thread again.
Discussion Starter #18
Apologies mate having to sift through and try to pick out the bits I need and see where to source. I understand next to nothing about how suspension is made up so 98% of the time I don't even know if what I'm looking at, is actually what I need.
Just sent off a message to cougar power about the tension rod bushes or bush kits they can supply, and ordering hardrace front and rear arms. Thanks for your patience :nervous:
No worries, as long as you get there in the end :thumbsup:
Cougar will see you right for sure. Good prices, i cant fault them.
Just make sure you take the car to somewhere who knows the the flip they are talking about regarding suspension setup and I dont mean kwikfit :chuckle:
Find the best guy you can to do it, pref with a motorsports background who uses fishing line etc :)
A lot of so called alignment shops out there talk out their anus and couldnt set up suspension if their life depended on it and the gear they use is usually out of whack too. I had a so called professional setup. Professional setup my ball sack, was £75 worth of sloppy dog turd.
Expect to pay upwards of £250 for a proper setup.
Good luck.
1 - 20 of 28 Posts
