1 - 12 of 12 Posts
hi peeps
firstly, i have done some serching and am still unable to find a good definative awnser to my question so please no use the serch button jokes!lol
i am very unsure on what camshafts to use in my engine build and wanted you guys oppinions
spec will be to aim for 700+hp
forged rods and pistons
cometic 1.3mm head gasket
n1 oil pump and water pump
stock valves
single turbo (gt4094r)
jun inlet plenum
haltech sport 2000 ecu
apexi evcr boost controller
4inch exhaust
trust sump extention
100mm front mount intercooler
only thing i cant work out is what cam's to run?
so any help would be great
thanks peeps
alex
tomei 280/280 11.1? lift (cant remember exactly) lift cams?
seemed to work well on listerofsmegs 650ish car.
you going to port the head or anything like that? what size pistons you gone for? as much help spooling the turbo i imagine would be appreciated?
stock size pistons, as for the head i was thinking about that too
thing is i heard that anything over 10.25mm and you have to cut a recess in the pistons to clear the valves
No, you need to releive the head to clear the cam lobes.
Having seen 905hp from an RB26 with 260 degree cams , I might need to rethink my logic.
right his were 10.8mm lift cams, he didnt have the pistons machined from what i recall, just a decent amount of headwork. no porting but new valves, springs etc.
whilst off id personally do the head, may as well! only want to have to take it apart once lets be honest! once done it is done!
neil did then change to a fully ported head with smaller cams and it did have good response. 272's matched with a decent spec head could be on to a winner?
its all in the tuning as well dont forget, depends how the mapper sets the cams and bits up!
thanks for the info guys, i will get sone headwork done
whatever kit i get it will have good springs and retainers etc
im now wondering who i can get to port out the head?
alex
Discussion Starter · #8 ·
update : i have decided to go for tomei type B cam kit, with springs and all
so i will let you guys know if there any good, i hope they are!!! lol
alex
Discussion Starter · #10 ·
what gives you that idea?
ive never seen one fail and if you serch here you get good reviews on the n1 pumps
the other factor is a tomei, greddy or hks pump are around a grand to buy then postage you wont get much change from £1200
but i will keep you guys informed, i dont imagine it will be a problem tho
alex
Discussion Starter · #12 ·
OMG!!!!!
thanks alot for pointing this out for me mate, you just might have saved me another very costly rebuild.
i will definatly not be fitting the N1 now, no way
like the other threads say, spend a bit more now and save yourself another engine failure
thanks again
alex
1 - 12 of 12 Posts
