I'm getting desperate, i'm spending good money after bad and i can't afford to send the car off to a tuner to charge me 'X amount' for a problem they aren't sure what it is :bawling:
Its misfiring very badly at various times between 2000 - 4000rpm in each gear except first,It flies afterwards...
Has anyone got a spare coilpack i could drop in to check if its that? I can fit it there an then and give it you straight back once i know what i need to
I Can't keep buying parts and hoping they'll fix the problem as its bankrupting me after christmas
I've got six you can borrow to try, and then if that doesn't work I have a set of splitfires you can try. Have you got a PFC yet? if so I have a z32 AFM you can try if the coilpacks make no difference.
Simon
mr uk I have got my gtr ones you can borrow to test your car.
