1 - 9 of 9 Posts
On my car the noise from the bell housing bearing is normally very quite after 3 sessions on a track day on Monday it became louder after each session. Rattle on start up then would quieten down after a few second the final time upon leaving was quite alarming from inside the car after the drive home and start up the day after its back to unnoticeable again. I fancy entering another track day, is this anyone else has experianced Thanks.
Can't help with track day experience but my car is on the original bellhousing at 44k miles and some days it sounds pretty bad then it'll go a few weeks without seeming to make any noise. It's weird.
Are you sure it's the bellhousing bearing, normally if you rag the car then it makes the clutches noisey, try doing a clutch learn
If you've got a bell housing issue it definitely gets worse when the car is being driven hard on track due to the heat.
The way to check bellhousing rattle is to leave the yin neutral rev it upto 1800rpm and if you feel a vibration in the floor then it's that.
1 - 9 of 9 Posts
