1 - 11 of 11 Posts
I have an (S13 200sx) RB26 using twin steel internal turbos..It is drift car that gets very hot when drifting.I have tried all the usual things like using twin electric fans as well as the viscous fan,Koyo rad,ducting,no stat etc and it still gets very hot very quickly...
I used to run no water feeds to the turbo on my last drift car(SR20 engine s14) with great results. I did 20 drift days and it never ran too hot or overheated.The turbo stayed in great condition and was standard turbo for the engine..
My question is,can I bypass the waterfeeds to the turbos on the RB26??..and has anyone else done this??
thanks:thumbsup:
seems wierd that its getting hot after all that? ive seen skylines going round the track non stop with no heating issues.
When you say going around the track,do you mean drifting??...as drifting is major engine punishment, without decent airflow to the radiator due to angle of car and reduced road speed in comparison to engine revs..
as long as its not a ball bearing turbo you can run with no water feeds. I have ran loads of turbos this way with no issues.
My big Apexi AX75 I have just now doesn't even have the ability to run water feeds however its a roller bearing tubby and not ball bearing.
Personally i dont see an issue with removing the water feeds mate. As usual though you will get some folk who will prob come on and disagree implying that the world will end if you do it ! LOL
On stock turbo's the water feeds are there becasue manufacturers know that your average joe wants to jump in, drive then switch off and not let it sit idling to cool for a bit before switch off. The water feeds aid the cooldown but if you look after your car and let everything heat up and cool before and after use then theres no reason not to ditch the water feeds.
If you look about you will see that alot of uprated turbo's dont run water. Also on lots of garret ones they give waterr cooling as an option so you can either have it or not. The rest of the turbo is exactly the same.
Discussion Starter · #9 ·
To be honest I was just confirming my suspicions that it would be ok to do this as I have done it before on my last drift car with no problems...
I was also thinking of fitting an oil cooler so the extra heat not absorbed by the water would not overheat the oil...thanks for your replies:thumbsup:
a big old oil cooler will certainly help :)
my ex-mechanic told me that my t76 would be fine without water cooling and just with an oil cooler, i soon proved him wrong and turned it bright red, thankfully it didnt cause any damage though...
you're probably fine to run it without water cooling as long as you stick an oil cooler on there, dont abuse it ridiculously, and give the oil and turbos enough time to cool down after/between runs :)
i use to run my cossie without water around the turbo all the time i had it which was about 10 years ,, the amount of water that going around the turbo and the heat its makes it wouldnt even touch the inside metal to cool the turbo anyway ,,
1 - 11 of 11 Posts
