1 - 7 of 7 Posts
Hi,
I have a problem with removing my spoiler blade.
All the bolts are out exapt one. There is one last nut wich is turning free in the blade and i can't reach it to hold it down. this is a very poor design from nissan :mad:
there is also a small hole under the blade. what does it do?
it's the last rear torx.
need to carefully drill the head off then deal with the free bolt once the blade is off
had the same issue with my genuine 400r carbon blades....was definately a brown trousers moment but got them all out eventualy which included 3 being drilled
how did you deal with rest of the bolt sitting inside the blade?
how did you got it out?
i managed to drill 2 out and the other took an hour of careful moving back and forward to remove it
a mates i managed to drill a small hole and pour glue inside to try and stick it which did work for a time and when bolt was nearly out it span again and we gave up as he wanted it back on his car to go out so bolted it up with out that one
1 - 7 of 7 Posts
