1 - 9 of 9 Posts
Dunno if you chaps have seen this.. pretty good to watch bit of a tear jerker heh.
Anyone know If she's still has the car or if it's changed hands?
https://youtu.be/zh98HlAYPY0"> https://youtu.be/zh98HlAYPY0" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350">
Sent from my SM-G920W8 using Tapatalk
Thanks. Just posted my thoughts now should have guessed you lot would be all over it heh.
The wheels were nice overall I imagine the studio weren't allowed to fit the other due to kerbing and possible buckled or twist. Producers won't be allowed to cut corners on something as important as that if there's even a slight chance.
it bugs me they bodged the cam belt change and didnt put another pump on. still a great episode and did a nice job of the car. i suppose the belt was a quick fix/precaution so they could save time and run the car safely. it wouldnt be a big deal to change the belt/pump ect at a later date
Discussion Starter #9
Yeah it's not like we saw the car being ripped open and pushed hard. Thing is tho from a POV of doing the cam belt and not losing timing it's pretty smart trick. Unless you skipped a tooth and didn't know lol but I always turn the engine manually off the crank bolt a good dozen times to be super sure heh
1 - 9 of 9 Posts
