1 - 9 of 9 Posts
I have the front and rear camera kit with the handheld remote for switching inputs. Suddenly the remote has no response and I can't get the front camera to show or the remote no longer overrides to show either camera when I'm in anything other than reverse.
The reverse camera still shows when I engage reverse.
Anything specific I should check? I've checked the wiring under the bonnet and that all seems ok.
I discounted that because the red light on the remote still illuminates when I press the buttons.
Is there a switch box or something that could be faulty and not responding to the remote anymore?
Change the easy things first, battery swap is a must
Takes very little current to light an LED, much less than what's needed to transmit the required signal.
1 - 9 of 9 Posts
