As above does anyone know off the top of there head what size bolts i need?
Thought my car was louder than usual this morning so looked uuderneath to see the tail to cat part isn't connected so bolts have came loose or hit the exhaust on something :/
Looking to bump some bolts from work before i head home to sort it :p
Depends on the clearance you've got - my system is so big that M12 bolts don't fit too well as the heads foul on the flange welds!
I ended up using M10 bolts, anything from 30 mm length should be fine.
There's plenty of clearance to grab 50/60mm bolts and play it safe :) the longer the bolt the more chance you've got of finding them next time they fall off! :p
