How to switch languages?
Found this on the internet.
I have the same problem.
The guide does not work
.A friend loaned me his old CONSULT 1. The battery has been dead for over a year. I recharged the battery overnight, so it boots now, but to ERROR 203, and the character set is in Japenese
I assume there is a special key-combination that needs to be executed prior to starting the CONSULT, since there are no other buttons/switches
thxFirst remove card. at the same time press ON button and the squares upper left and right on screen. ( you may have to do this a couple of times until you get the correct sequence ). When correct it will say insert card?? type the letter Y ( insert purple card ) it will start to load....you will have to hit enter as you go. Thats it
