hi,, I bought and awaiting arrival GTR 2015 american spec ,, I want change the rear diffuser to put jp spec OEM 2011+ ( with fog lamp ) becuse the american specs Do not come to these specifications ,,After searching versions No fog switchin in US spec ,,
Is there conector rear under the car to conact fog lamp ?
If replaced Headlights switch to JP spec is it same wiring to run fog lamp ?
Is one of you try this method?
thank you
thank you
