Evening All,
Been knockin about the forum a while, just wondering if anybody can help?
I changed the oil on my skyline recently and ever since then its not been working.
The car will now not start, and ive tried everything ( that i can think of! ). Trying to start the car it fires on 2-3 cylinder but wont catch.
Firstly, the car is running on a Power FC DJetro so AFMS arent a problem. All sensors have been checked and are fine, CAS sensor is fine and have even moved this while cranking, again no luck.
There is a spark, there is fuel.
I have changed the coils, the spark plugs, the amplifier, and treble checked the injecors ( these fire fine ). I have also uprated the fuel pump and changed the fuel filter.
I have checked the pulse signal on the PFC (pin 17) again no problems. I have also checked the ecu on another car, and the other car ran fine with there map on it ( my map was solid, no problems before oil change!! ). I have done a compression test on all cylinders, again everything is spot on.
The only thing that i can think of is that the voltage to the PFC ( checked on pin 58 ) drops to 10v on cranking, but im assuming this is normal?
The car has not got a cold start valve as this has all been removed, but it started fine before the oil change, and nothing else has been changed.
I really cant think of anything else to check!! :bawling::bawling::bawling:
Any ideas anybody? ( yes theres petrol in the car!! )
Any help very much appreciated!!
SI
SI
