any advice greatly recieved, r34 gtr ran 1.0 bar on stock turbos, oil seal failed so replaced with -7 that came with new actuators, all fitted correctly but took it for mapping and will only make 0.8 bar now. obvious things have been checked, vac pipes, boost leaks.
car doesnt have a boost controller was just running de-restricted boost on stock setup.
was thinking weak actuators but mitivac test shows opening at 10psi same as stock actuators when tested
