Had some real shitty luck were my getrag is scrap and had to buy a new one. So you can understand how the box is going to be precious to me.
Okay you've covered the the main bit, but because mine is a v-spec, something about the rear oil coolers and making sure you put extra oil in cause the coolers and pipes store abit inside thus lowering the amount in the box.
Then there's pressure issue, some one said circulate the oil then top it up, the system should now have adequate oil.
Please enlighten me cause its just too much information. If you could explain in sequence it would be much appreciated:thumbsup:
