Hi.
Just after some advice before I go ahead and try this.
My mate has replaced brake discs/pads on other makes of cars but not on a gtr35 , and his not fitted braided brake lines either before though has bleed out brake fluid and replaced with new stuff.
So is this an easy job to fit braided brake hoses? ( ive got the front and rears here , they were made up and supplied by Tim at circuit supplies ).
I also bought 3 x 500ml Motul RBF600 Brake Fluid 100% Synthetic Performance DOT 4 - 1.5 Litre.
Also my mate said is it just the same as bleeding the brakes where you start at the rear and work forwards??
CHEERS..
braided brake lines are no different from any other brake line from a fitting perspective. bleeding should be the same as for any ABS equipped car.
Sweet cheers , sounds a doddle. All I got to do now is go and stock up with some beers to pay him in :smokin:
