Hi, does anyone use a trickle charger through the 12v socket and hence know if it works please? Peter
I also attached the ring clips on to the terminals but fed the wire upwards so it popped up between the bonnet and windscreen as there is the soft rubber seal between them which doesn't damage the wire.I put the clips on the terminals and pass the cable out on the corner headlight/bonnet and the bonnet closes with no issues
