I bought this to do it up and use it but I have started another project so think I will let someone else have ago...
Have done a leak down test and all cylinders are good all between 10-18% leak, compression test all fine too.
R32 GTR
Wine Red
132231km
J Plate 1992
Trust front pipes + decat
Trust cat back exhaust
Hasemi 6 spoke 2 piece alloys good tyres
Greddy BOV's
Greedy Profec boost controller
Greedy 60mm boost gauge
Nismo Gear Knob
Quick shift
Momo steering wheel
New Alcantara gear lever and gaitor
New 5 piece car mats
Apexi airfilter kit
NGK Iridium 8 plugs
Sard fuel pressure regulator
Uprated fuel pump
Adjustable front top arms
Drilled front discs and grooved rear discs
Uprated clutch
I have put a new cambelt and rear steer arm on and have changed all oils.
The stuff that needs to be done to make it perfect >>>
Basically it is the body work that needs the attention it really does require a respray if you want it perfect, drivers rear quarter has a dent and passengers
front wing has dent and most panels are scratched.
Gearbox works fine but the input shaft bearing is noisey and would need replacing to get rid off the whin at idle, bearing doesn't cost much about £80
Think I have told you everything that needs to be done any questions you have just ask, and will get pictures sorted on request..
£3000
Darren
R32 GTR
Wine Red
132231km
J Plate 1992
Greddy BOV's
Nismo Gear Knob
Quick shift
Momo steering wheel
Apexi airfilter kit
NGK Iridium 8 plugs
Uprated fuel pump
Uprated clutch
£3000
Darren
