Not much detail to go on, but are you buying two or four tyres?
If it's just two, are you sure that under load they still have same difference (assume it's diameter you are referring to), most drag radials squat on launch, so it's a bit of a changing scenario going from launch to higher speeds
Yes only buying 2 rear drag radials which when you put there size in to a tyre calculator the circumference is slightly smaller. I know there is a limit before this is bad for the transmission on a 4wd car , but I don't what the limit is
Related Threads
GTR Forum
2.4M posts
69.2K members
Since 2001
A forum community dedicated to Nissan Skyline GTR owners and enthusiasts. Come join the discussion about performance, mods, troubleshooting, body kits, classifieds, maintenance, and more!
