Hello,
I installed an oil cooler and had to remove my plenum. I replaced all the gaskets, and also cleaned the throttle bodies as there was a fair bit of carbon buildup. At the fully closed position it was hard to see if the throttle bodies were opened but looking at them with a light I could see they were opened (not much but a bit). Now I have everything back together and my idle is now at 1700rpm (before idle was 950rpm). I tried to adjust the AAC but it did nothing even with the screw bottomed out its at 1700rpm. I'm guessing the throttle bodies have to be adjusted but I am unsure.
If I should adjust the throttle bodies what is the best way.
