Hi all when arming the Clifford G5 AvantGuard 5.5 (wrong model posted on thread title) on my R33 GT-R the alarm should beep 2 times. All of a sudden its now beeping 4 times to arm.
From what I understend this is due to the alarm thinking a door/bonnett or boot ect is open. I have checked everything and its all shut.
Was working perfectly yesterday. Have not messed about with anything with the car ect so have no idea whats causing this :(
Any suggestions would be of great help.
Thanks in advance
Discussion Starter · #2 ·
Upon inspection turns out it was the actual switch that the bonnet presses down on to tell the car alarm its shut.
The plastic pole that goes down was bent so did not create a circuit. I removed the wire flipped it around and it now works.
Does anyone have a replacement please?
J
ebay is best bet, or a local electronics store may have something that will do the trick. will be a generic unbranded part tho.
