Exedy (I think that's how you spell it) organic, should be good for up to 400bhp?What clutch you gone for Legan?
where are you getting the work done , local ?
Andy
Is that the gearbox oil seal?rear oil seal
Engine seal,but it wouldn't be a bad idea to do both crank & gearbox seals while the box is outIs that the gearbox oil seal?
The Exedy Clutch is just a little bit heavier on the pedal compared with the std. All in all happy with the result
