So I did this on my R33 GTR but straight away I get a horrible vibration from 4K upwards and it’s worse when I operate the clutch.
Any thoughts or experience would be appreciated.
Is the damper designed to mitigate that vibration? I know in my McLaren the damper damps vibrations that the knock sensors pick up, so when it goes, or you remove it, at a certain rpm it triggers the the knock sensors on the 2nd bank!
So its probably absolutely fine but you are just feeling some NVH that was always there, just hidden?
Thanks for the replies.
mad far as I know it’s just to smooth out the gear changes that’s it.
No I didn’t do anything else when I removed the damper.
