1 - 12 of 12 Posts
Guys,
What clutch do you suggest for my newly acquired GTR w/ around 600 hp? Currently it has this rock like twin plate racing clutch... it's very good but, its kinda tiring when driving in traffic situations.. :p I want something that is a bit friendly w/ my feet and hands during changing gears, but would still retain the car's track time.
A friend suggests exedy carbon type... so please help me guys.
Thanks in advance!
Sounds like you have a HKS clutch
OS Giken nice but noisy
Twin plate Nismo = all the noise of stock (ok, small rattle) but smooth as you like
NISMO all the way. Need to budget for the slave also as a standard slave doesn't extend enough.... Or is it too much?? Can't remember, use search
Nismo actually specifically says not to use a nismo slave cylinder with the twin coppermix. The nismo slave is bogger in diameter and therefore has less travel so it might not disengage the clutch completely.
As mentioned above, the factory slave should be used.
The Nismo slave should only be used for metal disc clutches.
im currently gettin an ATS Carbonetic twin plate fitted at the mo..
drove both metal twin plate (dont know what brand it was though) and carbon (ATS) and the carbon has a much smoother bite..
i have the os giken in my 33 and its not bad at all, a little noisey but fine on the road and good for 600bhp+
1 - 12 of 12 Posts
