about a year and a half ago, my clutch hose started to leak. So I went ahead and did up my clutch system - clutch master cylinder, clutch slave, Nismo braided hose. My clutch pedal worked fine of course, but it now had a bit of sag - maybe 1.5~2" of travel before the pedal started working the hydraulic fluid. Removed the whole clutch servo booster. No joy, still the same.
Since it wasn't any big deal, I'd just left it for some time, but recently, as I had some leftover Castrol SRF, I had the clutch system flushed and bled. It's slightly better but STILL no joy.
The clutch master cylinder I got was used - could that be the issue? is there some kind of zenki/kouki thing with R32 brake cylinders? Or just some misadjustment in the master?
I've ruled out clutch fork or pivot, as those are both just a couple years old, and the pedal sag wasn't there before the leakage started.
I do want to sort this out because A: I'm a complete perfectionist with my car and B: with the reduced pedal range it's a little bit harder to be smooth with my Nismo Coppermix twin - if I'm not 100% accurate recently I've found myself to be jolting the drivetrain on clutch engagement.
