should my clutch servo have a one way valve (check valve) because i cant see one but according to the service manual it shoud have inbetween the u shape rubber pipe and the servo itself, i have a really loud air leak noise coming from my pedals especially in higher gears with engine under load, if i gently touch the clutch pedal it stops, my clutch is also slipping in 4th and 5th but its fine when accelerating in lower gears, instead of the check valve i just have a 45 degree connector (covered in electrical tape) any help would be much appreciated
