Hello,
I have changed the clutch slave cylinder on my R32 GTR.
I'm trying to bleed the clutch oil to remove the air into the system but I think I'm doing something wrong because the clutch pedal keeps feeling too soft.
Here is what I do :
I have done this around 40 times and the pedal keeps feeling too soft.
Am I missing something or is it something else to do ?
Thank you
Here is what I do :
- I keep the clutch oil level on HIGH during the following steps
- Press the clutch pedal 5-10 times (engine not running)
- While someone else keep his feet on the clutch pedal, I open the bleed nipple on the clutch slave cylinder to release clutch oil and air bubbles.
- Close the bleed nipple.
- Release the feet on the clutch pedal and press 5-10 again...
Thank you
