Last saturday I fitted some coilovers on the back (koni), the front already had the koni coilovers on. Now the 4wd was running fine. As soon as I fitted the rear ones the 4wd light came on.
A week later (today) I start up the car and see what the fault code is however the 4wd light hasn't come on and can't check for the code (red light flashing), car has been started for around 15mins and seems to be fine.
I didn't drive it though, I'm guessing I should drive it first and it should come on? But when I fitted the coilovers it came on straight away, without moving the car.
Even if the light comes on again has anyone else had an issue with fitting coilovers and the 4wd light?
Thanks in advance. The car was really dangerous in 2wd plus icy roads, how we take the 4wd for granted. :chuckle:
