1 - 9 of 9 Posts
Firstly, I know that I should use the search function to find this - I have! And couldn't not find.
I am looking into buying camshafts...
I have a question regarding camshaft differences between R32,33 and 34 GTRs.
I have seen R34 camshafts have different part numbers to the R32 and R33. HOWEVER, I have seen some different makes with the same camshaft part number?
Are there any physical differences with the camshafts?
Of course, I am comparing the same lift and duration, so its not that.
Is it possible to interchange them all?
Thanks for any advice!
Inlets are the same, exhaust are different due to R32/33 Cas sensor being different to the R34 in its drive engagement. We can supply cam shafts pm me your requirements.
Skyline Section Manager
You can interchange camshafts between R32, R33 and R34 although the R34 runs a different camshaft position sensor. You can use the R34 camshaft sensor on the R32 and R33 if you swap 2 wire over in the plug or on the ECU.
Discussion Starter #8
No no, I know my username is R32, but actually I traded in for an R34. I now own an R34. Apologies for any confusion!
All becomes clear now :) you just needed dedicated R34 exhaust cam. Drop in replacements and no messing around .
1 - 9 of 9 Posts
