just got my gtr back from garage after fitting rebuilt steel turbos and a new gearbox.
the coolant system was all redone as was oil etc.
the problem is wen i check my radiator in morning wen cold it seems a little low, water is just sat were the fins are (i thought it should be up the neck of rad??)
and a couple of times i have put about a cup full of water just top it up. but everytime i check it, it always seems to be a bit on the low side
i have checked for leaks on all pipes etc
car is not overheating
no mixture with oil
does any one know were this cup full of water is going??
could it be my rad cap or is it serious?
cheers ant
no mixture with oil
cheers ant
