1 - 20 of 23 Posts
HELLO GUYS,
I WAS JUST READING YOUR THREAD ABOUT THE RINGED MOTOR AND YOU SPOKE ABOUT USING THE CORRECT FUEL. I USE OPTIMAX WHERE POSS, BUT NOT SURE WHAT TO USE WHEN OPTI IS NOT AVAILABLE. THE IMPORTER OF MY CAR TOLD ME TO USE ANY UNLEADED. CAN ANYONE PUT ME RIGHT.
CHEERS.............NEIL:eek:
I wouldn't use normal unleaded unless you have a replacment ECU mapped to that grade of fuel. Use 97RON Super as a minimum.
I tend to use Optimax + Octane booster just be safe as its only £2 a bottle.
Fuel
Optimax or any SUPER u/l if you can't get Opti and with octane boost for track days
Keep it on the Black Stuff:eek:
I must say this seems a bit strange to me.
I can understand Hard Tuned GTR's needing it all - but I have been told that for a GTS just go down the list so if Unleaded is all they have then have it but dont drive like a nutter and keep the revs down - dont over fill it thus when you can get to the next station you can dilute it (is that the right word) with the good stuff.
Re: Fuel
Same here, SUL for me all the way (nowhere close does Optimax - but I fill up with it when in an area that has a station).
I personally wouldn't bother with octane booster unless it was a track day.
I know a lot of you will know, but for those that don't... In Japan the fuel is rated at 100RON, UK Optimax is supposedly 98.6, UK Super is 97 and UK NUL is 95, octane booster will generally add 1 or 2 points. RON relates (although I am not sure how) to the temperature at which the fuel ignites, the higher the RON rating the higher the temperature that is required to ignite the fuel.
Japanese engines are obviously mapped to japanese domestic fuel (i.e. 100RON) and running them on a lower quality fuel (i.e. one that ignites at a lower temp) can mean that the fuel will ignite before the spark, this is called det(onation).
When det occurs, the explosive force produces a sudden rise in cylinder pressure accompanied by a metallic pinging or knocking noise. The shock waves created by det subject the head gasket, piston, rings, spark plug and rod bearings to severe overloading.
All modern cars will have a 'knock sensor' that allows the ECU to detect det, and do something about it. The usual way the ECU will fix this is that it will retard the ignition (spark earlier), but often with Japanese cars the fuel quality between 100RON and 95RON is that different that they cannot retard the ignition enough, so under load/high temperatures the engine will be detting.
The solution to this is either to reduce the temp of the fuel/air mixture entering the engine (by fittment of a bigger intercooler, water injection etc.) or use a fuel that doesnt ignite until higher temperature, i.e. one with a higher RON rating.
It is obvious that using a higher octane fuel is a lot cheaper than fitting water injection, and certainly cheaper than an engine rebuild.
Turbocharged engines generally run hotter than the average NA engine because intake temperatures are obviously higher due to the air being compressed by the turbo. So I would say det is more of an issue to turbo'd cars than NA cars (I have no experience of NA Jap cars), but I for one wouldn't take the risk.
Cheers Simon thats dead good, finally it is explained, I have been wondering why RON Ratings were so important!!!
I now know thanks matey!!!
Draxx
Future user of Optimax, if I can find a SHell near me that is!!!
Even less people know that the above isn't actually true :p (except the part about UK fuels)
There seems to be a lot of confusion about this - I used to believe that Japanese fuel was 100RON, but apparently it isn't, as Shin once said:
At first, many people believe Japanese petrol is 100, but the octan in Japan is not 100 actually.
It is usually 97.5 to 98.0.
See this thread for background.
You are right Durzel, I didn't know that :), but everything I have said still stands. As I have said, the ECU will probably be able to retard the ignition enough to cope with 97/98RON, coping with 95RON NUL is a different kettle of fish.
Draxx, that's right, use SUL. What you'll probably find is that you'll get extra MPG from using SUL as the engine is running more efficiently. The money saved from the extra MPG will very probably more than equal the additional cost of SUL over NUL. This was certainly the case with my old UK Impreza turbo.
just to add to the confusion...
... I understand that if you use Optimax then Octane boosters have little or no effect as the fuel doesn't seem to respond the same way as SUL due to the additives it contains :rolleyes:
Always used to run the Jap spec Modified Scooby on SUL or Optimax, but there are a couple of other problems with fuel etc-
1 Its not always use of the wrong fuel grade that kills the engine, but the fueling not being remapped correctly for modifications - There are lots of people who don't fully understand tuning japanese cars (though fortunately lots of good ones too)
2 SUL goes off... If the garage doesn't sell much then the chances are it will be stood around for ages and will degrade to a similar level to normal unleaded :)
- I hope that helps :eek:
I guess that means if we want to be 100% sure our cars are not detting then we should invest in aftermarket knock sensors/gauges like the scooby boys do.
Has any one fitted an aftermarket knock sensor/gauge? I guess there is no reason why the knock link (as used on a lot of modded Imprezas) wouldn't work with a Skyline.
Octane boosters in a can arn't worth it IMO...
The ONLY Octane booster that can really be used (with optimax as well) is Toluene.
10% mix to your fuel.
Toluene is 114 octane so it ups the 98.5 of optimax to nearer 100 octane.
Millers, silkolene etc just too small a bottle to have any real impact IMO...
Having said that Optimax on its own is what I use unless I'm going to the track...but really I'm just buying optimax to try and win something on the scratch cards!! :D
Spot on. 95 RON is just not the Skyline's favourite cup of tea. Treat your engine to too many doses of 95 RON medicine and pretty soon Mr and Mrs Piston nextdoor will find themselves relocated to another neighbourhood. :cool:
In other words, as Simon said, stick to 97/98 RON :)
Now that is scary, I didn't know that.
Hmm, my local Esso garage does SUL but there isn't a lot of high performance cars in my region (bit of a sweeping generalisation, but I haven't seen many on my travels).
Super. Has to be..
when buying a car ask the owner what fuel it has run on. If it has even had a tank of normal unleaded then the damage could even be done.
I have a UK Vspec and it says 98 Ron and above. If you do it cheap and put in normal UL, then for the sake of 4 p a litre you can kiss piston 6 goodbye.
the effect of normal UL is that the engine is starved of octane and causes undue stress on the pistons and prevents the cooling that is needed as the engine has to work harder to get the spark.
All it takes is one blast with normal UL and that could be it. think of the stresses at 7000rpm and it makes sense.
So SUL is the deal with octane booster on track days.
Either that or get yerself down to blackbush airport, sweet talk the guard and get yourself some aircraft fuel.
Sth like 115-120 Octane. NICE
NLW
fuel/booster
I disagree. I had my r33 for a couple of years and 90% of the time I ran on on UL and sometimes when I could on SUL as I couldnt buy it locally.
I went uphill, downhill, sideways and backwards flat out 110% of the time and even used it on track days.
name me the people whom have detonated theirs cars which was entirely due to using UL, cos I tell ya wot, I couldnt have driven my car any harder than I did and it was spot on.
As for boosters, they do work depending on what type and quantity you use, they can make a noticeable difference to the car as well as making it run cooler.
Everyone knows that running sul or Opti is better 4 yr engine but just cos you fill up with a few tanks on a regular basis dont mean you should get your cheque book out straight away.
Worry about it when it blows up.:) :smokin:
1 - 20 of 23 Posts
