Could some one help me, Is the correct off set for a 18s on a GTR 33 +12?
Wheel size sorted 18x10 or 18x9.5 depending by make. Does the +12 mean you need a wheel spacer or not?
...Ian
R33 GTR wheel sizes
Ian,
The info you need to give wheel suppliers for R33 GTR wheels is:
Size = 10x17 or 10.5x18 inch
Offset = +20
PDC = 114.3
Hub = 66
and of cause 5 holes.
Tyre sizes are:
245/45/17 or 275/40/17
265/35/18 or 275/35/18
To answer your question I think you do need a spacer to bring your offset up to the required +20.
Hope this helps.
Paul.
PS the offset is the distance in mm from the center (as you look at the wheel end on) to the edge of the hub.
So.......
thanx for that,
So if I wanted a set of 10x18 or 19.5x18's the correct off set so as NOT to have to have to use wheel spacers would be +20??
If thats correct my Nismo GT3's would then be 10x18 +20?
..Ian :confused:
