I have come across a Getrag 6spd GTR box out of a R34 without a transfer case, could you fit a R32/R33 transfer case to one?
Nope! Diffrent size main shaft plus bolt pattern is diffrent!
R34 transfer boxes are as rare as rocking horse on there own! Believe me I've tried.
I figured that might be the case, if you could get past those things (custom spacer/adapter and machining spline) would the 5 speed "stirring stick" work in the 6 speed? The Getrag uses a "euro pull" to select reverse....
