1 - 11 of 11 Posts
OK the CAS on the end of the camshaft,
If you loosen the bolts and adjust it will it retard/advance the timing?
May seem a silly question but i would like to know please.
Yes AFAIK
Ian, you turn it to the left to advance ignition timing.
Be carefull as a little moves it a long way....If you know what I mean.
Best just hook a timing light up and have a fiddle and you will see for yourself.
Dunno about having a fiddle mate, sounds a bit risky moving it about?
I scratched a mark to know where it always goes if i take it off.
Cheers for the response.
I wasnt for 1 minute suggesting you should.:chuckle:
Mine died so I had to fit a new one. Was quite scary how much the timing moved by rotating it only a little.
Discussion Starter · #9 ·
Cheers.
By the way whats going on with that exhaust in your avatar!!!?
Cheers.
Knew it blew flames. Got a mte that's been doing all the filming for Time Attack and D1 and he has all the fancy mounts. Thought it would be good to strap a camera to the back and have a look.:D
1 - 11 of 11 Posts
